Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Volume displacement UV texture information to color /displacement?
2 REPLIES 2
f.ribbeck
263 Views, 2 Replies
I have recently been trying around with Lee Griggs' volume displacement technique and I wonder if there is a way to use the objects texture in the original UV space as an input to the scatter color channel or to the displacement channel. As far as I can tell the mesh volume does not respect the UVs of the original object (which I guess makes sense as it is now a volume without a clear surface), but is there maybe a way to use a copied decoy object and project the texture from there? Maybe Lee himself has some experience with that?
Labels (3)
2 REPLIES 2
lee_griggs
in reply to: f.ribbeck
I have not been successful with that. I just use the camera texture projection method.
Maybe you could try camera mapping the z-depth of the object to volume_displacement?
An alternative way could be to render the object with a fisheye lens and spherically project to the volume displacement? Not very accurate but might be worth a try.
Lee Griggs
Arnold rendering specialist
AUTODESK
f.ribbeck
Hi Lee, thanks for your answer. Yes I have also thought about using a rendered image to project, but then you would need to have your camera position set already, but in that case it might be working. I will try around more with that
The Z-depth approach sounds very interesting 🙂
