Hi, is it possible to use Arnold to create an alpha image/mask/black & white image from a color image?
This is the original color image:
And this is the alpha image I want to create using Arnold shader network nodes:
I want to make all the colors white, except the white background color, which I want to make black.
The reason I want to do this is because this way I don't need to maintain two image files. I just need a color image, then let Arnold generate the alpha image within the material.
I've tried using the Subtract node and plugging in the original image and white color, but I'm not able to get a clean alpha image using this method. Also, I've tried all different blending modes in the layer color node, but none give a pure black and white image. Does anyone know how to do this?
