Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Transparency Issue with Standard Surface Glass
3 REPLIES 3
ctoddadams
127 Views, 3 Replies
I have created 3 watch crystals in an environment.  1 crystral is clear as should be.  The other 2 are black.  I have been researching the issue but can't find a solution.  I am using Arnold with C4D r25.  I am fairly new to modeling and rendering but I can usually figure out an issue.  I can't seem to get the other 2 crystal to be glass-like.  Any help would be greatly appreciated.
Here is a link to the file
https://www.dropbox.com/scl/fo/k0owe3w7iz8420m2t17c1/h?rlkey=nisd3d4nwndyryk1jxit6jngl&dl=0
Thanks very much
3 REPLIES 3
Stephen.Blair
in reply to: ctoddadams
Add an Arnold Parameters tag to those objects and turn off Double Sided
// Stephen Blair
// Arnold Renderer Support
ctoddadams
That worked...thanks so much.  I greatly appreciate it!
Stephen.Blair
I had a bit more time today to look at this.
You can re-enable Double-Sided, then increase the Transmission ray depth. It was set to 3, and that's too low for the geometry. Setting it back to the default 8 gave the right renders.
// Stephen Blair
