Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
transmission_depth program turns off
1 REPLY 1
starcolor_a
145 Views, 1 Reply
When using the transmission_depth alone, the program works normally,
If you use transmission_depth and another transparent material at the same time, the program turns off.
The program will be turned off unconditionally when used at the same time without overlapping. How can I solve this problem?
Tags (1)
Labels (1)
1 REPLY 1
Thanks, I could reproduce the issue, we're looking into it.
