Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Transmission AOV Issue
6 REPLIES 6
6196 Views, 6 Replies
Hi guys I have a question. I´m really lost with this. I have a plastic material. But this plastic material has a roughness transmission. Like a silicone.
The thing is I need the alpha of this to work in photoshop. I need the alpha of the refraction with the roughness effect. But the alpha show me the entire object with no roughness. I´m working with Arnold 5.
I do not know which is the AOV to do this and how to use it in Photoshop.
Thanks a lot guys
Labels (4)
6 REPLIES 6
zenop
What would you want that AOV to look like? Have the alpha only where there are "perfect refractive" pixels? Comping rough refractions isn't possible (as far as my knowledge goes)
Stephen.Blair
There's currently no AOV or LPE that will give you an alpha for refraction. That's something we're looking to add soon.
// Stephen Blair
// Arnold Renderer Support
I will try to be more specific. I will work with 3Ds Max Vray and you will see what I need from Arnold.
I made this example in 3Ds Max and Vray:
As you can see in that image (Ca1.jpg) I made 2 boxes and one of them is a glass with roughness in this case the name in Vray is Glossiness. And when a select to see the alpha channel I see this:
Well I need the exact channel in Arnold. I can´t believe this option it doesn´t exist.
When I try to do this in Arnold I only see all white in the alpha channel with no roughness trough the box.
Thanks guys!
Stephen.Blair
Arnold 4 had a refraction opacity AOV, but there's no equivalent yet in Arnold 5.
// Stephen Blair
Thanks Stephen!...
Slava_91
in reply to: Stephen.Blair
Thank you Stephen, it would be great!
