Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
The arnold setup_cryptomatte.py script is not installed.
4 REPLIES 4
未郁_小黎
348 Views, 4 Replies
当我在 C4D 中设置 cryptomatte 时,他提醒我 Arnold setup_cryptomatte。未安装py脚本。不过之前安装的其他任何版本都没有出现过这个问题
When I set up cryptomatte in C4D, he reminded me of Arnold setup_cryptomatte. The py script is not installed. However, this problem has not occurred in any other versions installed before
Tags (1)
Labels (1)
4 REPLIES 4
That script can be downloaded from the docs. It was never installed with C4DtoA.
// Stephen Blair
// Arnold Renderer Support
你好,我查了下,好像不是这个脚本的问题,C4D文件夹里有这个脚本,但是不行,我试过重新安装也没效果微信图片-20210709104415.png微信图片-20210709104420.png微信图片-20210709104426.png
Actually the script is shipped with the plugin and it should be located in the library/scripts folder, e.g. c:\Program Files\Maxon Cinema 4D R24\library\scripts\arnold_setup_cryptomatte.py
The next thing you can check if the command exists. Go to Window > Customization > Customize Commands... and search for arnold_setup_cryptomatte.
Alternatively you can just run the script in the Script Manager (Extensions > Script Manager...).
您好,谢谢您的回答。我按照你说的查了下,在scripts文件夹中存在,命令也存在,但是在脚本管理器中无法运行。如果我尝试过其他版本的 C4D,它可以运行
