Texture displacement with Arnold in C4d
samuel.josling
samuel.josling
Hi, all,
I am trying to displace a png texture on a flat shape. I can achieve the effect without any problems using the standard renderer and a C4D material:
displacement1.pngHowever, when I try to achieve the same effect using an arnold surface shader, I see the following result:
displacement2.pngI am using an Arnold parameters tag. I have used catclark subdivision and set the displacement height to 20cm. Reducing the height smooths out the edges, but there is no observable displacement. Increasing the height makes the shape more crinkles.
My node map looks like this:
displacement3.pngDoes anyone have any suggestions regarding how to achieve the same displacement effect I achieved in the standard renderer with Arnold? Your help is much appreciated.
Cheers!
gomeslindsay
since its a flat shape change the subdivision to linear
lee_griggs
How many subdivisions does the object have in the Arnold Parameters tag?
Lee Griggs
Arnold rendering specialist
AUTODESK
samuel.josling
lindsay gomes you are right-o thank you
samuel.josling
It had a sufficient number according to every tutorial I watched - 8.
