terraform fx color
terraform fx color
guglielmo_natuzzi
terraform fx color
guglielmo_natuzzi
Howe can I use terraform fx (insydium plugin) gradient in arnold? I'm not able to import it and connect to an arnold shader
Any suggestion?
thanks in advance
peter.horvath6V6K3
There's no direct support for TerraformFX in Arnold. You have to setup your shading manually I'm afraid:
  • Create a ramp_rgb shader with the same gradient
  • Export the Altitude/Slope map of the terrain
  • Use the map as the input of the ramp_rgb shader
anedjaranas1234
doesn't work, all the projections of the ramp don't get it done... additional information would be appreciated!
peter_horvath
1. Go to the Preview tab of tfTerrain and export an Altitude map.
2. Use this map as the Input of a ramp_rgb shader with the gradient copied from tfTerrain.
Hope this helps.
// Peter Horvath
// C4DtoA developer
