Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Teamrender get stuck on 100%
2 REPLIES 2
leandro.cattani
127 Views, 2 Replies
Hello everyone!
When I try to render takes with team render, it gets stuck on 100%. If I render normaly, it renders all the takes. What I should do?
Thank you!
Leandro
2 REPLIES 2
Can you try to render the takes with the builtin renderer, just to see if this is a Team Render issue or a specific problem to Arnold? Is this a single frame render or animation?
// Peter Horvath
// C4DtoA developer
Was a single frame. But now I set Arnold to let one core to the system and seems works well. I have to say Arnold becomes more stable also when I use IPR. Was a single frame render. I'll let you know how is going to work now! Thank you!
Technology Administrators
