Team render Error
Team render Error
javier_arias
Message 1 of 8
Team render Error
javier_arias
We have a problem when we make a team render ...
Rendered parts change from the rest.
For what is this?
Is the problem in one of the machines?5240-captura-de-pantalla-2019-11-27-a-las-110903.png
Replies (7)
Message 2 of 8
peter.horvath6V6K3
I'm not exactly sure what's causing this, I was not able to reproduce it so far. Some ideas:
  • Different Arnold/plugin versions: please make sure the same version is installed on all machines.
  • Different preferences: maybe some settings are different on a machine, but as I see, clients have no color profile settings, so I'm not sure.
You can try to identify the misbehaving machine by enabling only one client at a time.
Are there machines with different operating systems (mixed Windows and Mac)? Should not be a problem, but who knows.
Also, do you have the same issue in other scenes, or only in this one?
Message 3 of 8
javier_arias
Hi
I have already identified the machine that causes this failure and it is the machine I work on and modeled the scene ...
All my machines work with the same version of Arnold and Cinema4D. In addition they are all Mac Pro.
I can't think of what happens ...
Message 4 of 8
peter.horvath6V6K3
So your workstation is incorrect, while other clients are correct?
Are you running the render from Studio, using your studio as a client, or running a Team Render Server?
Message 5 of 8
javier_arias
Yes, my machine renders poorly, while the others do it well.
I tried another job and it does well ...
Message 6 of 8
peter.horvath6V6K3
So maybe something in that specific scene is causing the issue. Would it be possible to share the scene with me or send it to support?
Message 7 of 8
javier_arias
I changed the teamwork and rendered it from another team.
Now the team that fails is from which I launched the job ...
Message 8 of 8
peter.horvath6V6K3
Hey, sorry for the late reply. I'm still not able to reproduce the issue. If it's happening only in a specific scene, could you please send me that scene? Also please let me know your Cinema 4D and C4DtoA version and platform (win or mac).
I also wonder what happens if you don't use any clients in Team Render, but render only with the Local Machine. You can also try to disable 'Auto-convert textures to TX' and 'Use existing .tx textures' to see if it helps.
