Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
SurfaceLuminance similiar in C4D?
2 REPLIES 2
pixelmonk
202 Views, 2 Replies
is there a way to recreate surfaceluminance node (maya) in C4D? I'm trying to integrate day/night earth maps on a globe, using a distant light. I know surfaceluminance is a maya node, but it works with Arnold. I wondered if there was an all-arnold approach?
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
in reply to: pixelmonk
MtoA converts surfaceLuminance to an all-Arnold shader tree.
If you export a shader that uses surfaceLuminance, you'll see this instead of "surfaceLuminace"
rgb_to_float
 name surfaceLuminance2
 input surfaceLuminance2/utility
 mode "luminance"
utility
 name surfaceLuminance2/utility
 shade_mode "lambert"
 color 4.48571444 4.48571444 4.48571444
// Stephen Blair
// Arnold Renderer Support
pixelmonk
works great. .thanks! I also forgot i could export the shader from Maya to C4D.
Technology Administrators
