Successful baking does not generate any file
Hi, I have a weird issue with baking, where it says the bake was successful, but there is no file being generated.
Whatever location I choose as file output, no file is being generated at all. I have the exact same bake settings as in other scenes where it did work perfectly fine before, but now it does no longer work. I attached a screenshot of the bake settings.
I have no idea what is causing this, I haven't updated to a new version and did not do any changes to admin rights or whatever. baing.jpg
And to add, I do use the CPU system for rendering
And the object I want to bake is not under a cloner or anything and visible in viewport and render, an Arnold standard surface is assigned to the object
OK, it seems this was a strange bug, after I restarted my system today, the baking worked fine again
peter.horvath6V6K3
Hmm, that's odd. If it comes up again, please let me know and I'll take a look.
