Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
standard surface node to bump2d doesn't work (stays grey...)
5 REPLIES 5
sandzombie82
1385 Views, 5 Replies
i have tried so many tutorials... but somehow. i never get to connect a standard surface to a bump2d node (normal stays grey) schermafbeelding-2018-01-16-om-225917.png
step by step i do the same thing but ... why can't i use bump...
please help.
5 REPLIES 5
You have to connect bump to standard_surface (Geometry > Normal)
https://support.solidangle.com/x/AIR2Ag
Bump shaders: bump2d and bump3d now output a normal vector that can be linked to new normal parameters in ambocc, lambert, standard_surface and utility shaders. These bump shaders no longer function as passthrough shaders.
// Stephen Blair
// Arnold Renderer Support
sandzombie82
in reply to: sandzombie82
thank you for the reply, i am going to try this....
i can connect now no visual effect but a step closer 😉
keep you posted!
gr,
sandzombie82
stephen blair.... thank you! you are my hero!.
it works ....thank you!
oytun_cecen
Thank you so much!
Worked for me. Thanks for the clear explanation.
