Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Stacked materials and alpha?
1 REPLY 1
mdouglas66J8T
194 Views, 1 Reply
Hey there, I'm fairly new to Arnold. I'm wanting to stack 2 textures and have the top one have some transparency (a mouth that will swap textures so it animates).
When I add the mouth overtop, its alpha actually cuts through both textures and makes that part of the geometry disappear. Is there a way to prevent this?
The alpha for the mouth is a separate B&W image and is hooked up to Geometry > Cutout Opacity. I've added a C4DtoA tag to the geo and have turned off Opaque. See attached image. On a related note, can Arnold see the transparency in an image without generating a B&W matte? Thanks very much!
Tags (2)
Labels (2)
1 REPLY 1
Use the alpha as the mix of the layer shader.
Or you could use the Image node in single-channel mode to get just the Alpha channel.
// Stephen Blair
// Arnold Renderer Support
