Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
SSS where to put put my scatter map in shader network
6 REPLIES 6
gomeslindsay
928 Views, 6 Replies
hello
I wanted to know when I create skin material in substance painter along with the SSS when I export I get a white texture/png under the name scatter I wanted to know where in the nodes to I plug in the scatter png also does it work if the skin color is all black the look I'm going for is the slitty transparent reddish look on the skin when light is behind the character
Labels (3)
6 REPLIES 6
lee_griggs
in reply to: gomeslindsay
sss_weight?
Lee Griggs
Arnold rendering specialist
AUTODESK
gomeslindsay
in reply to: lee_griggs
yes !!! I tried putting my scatter map in weight but it changes the color of my shader to white
lee_griggs
Can you share your standard_surface shader settings?
Is the subsurface_color white?
Also, watch this for skin shading tips:
https://www.youtube.com/watch?v=ss13J1emsvw&ab_channel=ArvidSchneider
Lee Griggs
AUTODESK
That goes into the subsurface> weight input, as it is a greyscale map. You can also paint a colormap for scattering in Substance Painter to add in the color input, or just use one color for everything (from the standard surface parameters)
In your case that color would probably be a red tone
And then connect your greyscale map to a ramp node to keep it from overshooting, otherwise you will likely get a massive scattering effect all over your character
gomeslindsay
8315-5.jpghey I tried the ramp node but still don't see results :// idk if my scatter map is right
