Hi It finally kicked this out after a minute or two :
I've removed some specific info where you see ****
C4DtoA License Diagnostics: 2018-11-20 11:03:20
test render (0.66 sec)
| log started Tue Nov 20 11:03:20 2018
| Arnold 5.2.0.1 [b9c11b0c] darwin clang-5.0.0 oiio-1.7.17 osl-1.9.9 vdb-4.0.0 clm-1.0.3.513 rlm-12.4.2 2018/09/10 16:20:31
| running on *****.local, pid=91967
|1 x Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz (6 cores, 12 logical) with 32768MB
|macOS 10.14.1, Darwin kernel 18.2.0
|soft limit for open files raised from 12542 to 10238
| loading plugins from /Applications/MAXON/CINEMA 4D R18/arnold/bin/../plugins ...
| loaded 4 plugins from 2 lib(s) in 0:00.00
| authorizing ...
| [clm] authorized for “********************” in 0:10.03
| [clm] expiration date: 2019/02/02, in use: 1/10
| [color_manager] no color manager is active
| [color_manager] rendering color space is "linear" with declared chromaticities:
| r(0.6400, 0.3300) g(0.3000, 0.6000) b(0.1500, 0.0600) and w(0.3127, 0.3290)
| there are 0 lights and 1 object:
| 1 utility
| 1 list_aggregate
| rendering image at 320 x 240, 1 AA sample
| AA samples max<disabled>
| AA sample clamp <disabled>
| diffuse <disabled by depth>
| specular<disabled by depth>
| transmissionsamples2 / depth2
| volume indirect <disabled by depth>
| totaldepth 10
| bssrdfsamples2
| transparencydepth 10
|initializing 3 nodes ...
| creating root object list ...
|node initialization done in 0:00.00 (multithreaded)
|updating 4 nodes ...
| no objects
|node update done in 0:00.00 (multithreaded)
| releasing resources
| Arnold shutdown
kick -licensecheck (1.74 sec)
RLM DEBUG for product "arnold"
In license file: /Applications/MAXON/CINEMA 4D R18/arnold/bin/.//arnold.lic (**********@**************):
Checking server machine “**********” ... server DOWN (stat: -1)
No matching products found in license file
Cannot contact license server
0 product instances found
Could not find any license files, please check the license server, the license may be expired
Please contact licensing@solidangle.com
environment:
solidangle_LICENSE = (null)
RLM_LICENSE= (null)
lmutil lmstat -S adskflex -i (0.22 sec)
lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Tue 11/20/2018 11:05
License server status: ****@**********
License file(s) on ***********************: ***********@192.168.************:
lmgrd is not running: Cannot connect to license server system. (-15,570:36 "Operation now in progress")
rlmutil rlmhostid -q ether (0.00 sec)
