Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Skydome Color slot shader network isn't saved with takes.
3 REPLIES 3
jrw2
156 Views, 3 Replies
Hi, I want to have several takes using a different HDRI shader network for the Skydome light color slot for each take. However, the shader network in the skydome isn't saved with the takes. Comparing with the native C4D workflow, you can change the material tag on the Sky node and save each tag to a different take. How can this be achieved using Arnold?
I've found a workaround, and that is to create multiple Skydome nodes with their own shader network and having each one activated for the different takes.
3 REPLIES 3
peter.horvath6V6K3
in reply to: jrw2
Yes, that's a good workaround. Could be a bug in the code, since that color slot is a custom widget. I'll take a look and try to fix it.
jrw2
in reply to: jrw2
Thank you.
peter.horvath6V6K3
in reply to: jrw2
Actually it's not an easy fix, it would require to introduce a custom data type, which breaks compatibility. So it probably won't be fixed in the short-term. You have to live with the workaround for now.
