Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Restricting atmosphere effects to a cube
2 REPLIES 2
314 Views, 2 Replies
Greetings to all.
Is there any way to restrict an atmosphere_volume to a cube or other enclosed mesh? I don't want to apply it to my entire scene- just a specific portion of it. I only need it to affect a certain group of lights within an enclosed space, and not the lights outside of that space.
I realize I can just set the volume contribution of the lights I don't want affected by the atmosphere to 0, but I'd rather not have to do this for each and every light that I create.
Alternatively, is there any way to make the standard volume act the same way as the atmosphere_volume shader does? I don't want the darkening effect of the standard_volume shader, just the nice light rays and shadows that the atmosphere_volume gives me.
Cheers,
-CMPX
Tags (1)
Labels (1)
2 REPLIES 2
zenop
Not sure about c4d specifics, but you should be able to do that using 3D projections / layered 3d projections in the same way as you’d map a fractal to the density. Just instead of it repeating through the whole world space, projections are contained to a certain size.
lee_griggs
You could try converting a cube to a mesh volume.
Lee Griggs
Arnold rendering specialist
AUTODESK
