Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Rendering smoke colors from explosia fx
4 REPLIES 4
SteffenJSDGK
250 Views, 4 Replies
Explosia fx is getting color from the xparticles emitter, shows correctly in the viewport but dont kknow how to access the colors in arnold....
Any suggestions ?
Tags (1)
Labels (1)
4 REPLIES 4
All channels from explosia are exported by default (since C4DtoA 3.3.2), so you should be able to just read the color channel (e.g. in a standard_volume or volume_sample_rgb shader).
If it does not work, please send us a scene and I'll take a look.
SteffenJSDGK
in reply to: SteffenJSDGK
I cannot get that to work..
Please take a look
https://we.tl/t-q9xe8dSiV8
Wetransfer link to project file...
Indeed, the Explosia FX integration is missing support for the color channel. I'm going to fix this in the next release. Meanwhile, if you need the fix right now, please request a custom build via support@arnoldrenderer.com.
Fixed in C4DtoA 3.3.7.1. You can now sample the color channel via the volume_sample_rgb shader.
