C4DtoA 2.6.0 [509cf977]
Arnold core 5.4.0.0
Open Render Settings window > Arnold Renderer > Main, scroll down so that the scroll bar is at the very bottom. Close any other drop down tabs if the Ray Depth tab is not visible. While the scroll bar is at the bottom of the window, in the Ray Depth tab, change either the diffuse, specular, or transmission params. The window scroll bar should jump up, making it difficult to adjust the parameters easily multiple times. Changing any of the other params in this tab don't mess with the scrolling.
Sometimes if you right click on the arrows of a parameter input box (not just in the Ray Depth tab) to reset a parameter to default then the window scroll will jump up. I can't seem to get it to happen multiple times unless you close and reopen the Render Settings window, as if to get the bug to start happening again.
