Render crashes in R25 but not R22
jakeD87JQ
jakeD87JQ
I've got a simple scene, it's a wine bottle with condensation. The condensation is causing the problem, if I remove the water surface and use something opaque it renders fine, but obviously that won't work as a solution.
I tried the same scene in R22 and it works with no problems.
Stephen.Blair
What versions of C4DtoA? Same or different in each version of CINEMA 4D? can you provide a scene file?
// Stephen Blair
// Arnold Renderer Support
jakeD87JQ
Thanks for your response. I had to switch back to r22 for this project, although I'm on a new project that has very little transparency and still the same issue. That is a very large scene so I'd prefer if we try to diagnose the first one. It's too large to attach so I put it on my drive:
https://drive.google.com/file/d/1RJhvf6eKiVyetEpuzcWaYBOIRtDQalm6/view?usp=sharing
Here's the Arnold info:
C4DtoA 4.0.2 [7632e4f8]
Arnold core 7.0.0.1
I'm on a AMD Threadripper PC, windows 10, 21H2.
peter.horvath6V6K3
From the log this seems to be the same crash, reported in https://answers.arnoldrenderer.com/questions/37946/crashing-again-when-using-opaque-with-render-or-i...
and fixed in the latest C4DtoA 4.0.3.2.
Please update c4dtoa and let us know if that solved the problem. Thanks.
