Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Render a standard surface to an AOV
3 REPLIES 3
zachary.mineo
307 Views, 3 Replies
AOV write has a passthrough and an AOV input. It looks like this WAS possible to write a standard surface as the AOV output, but that functionality got removed in Arnold 5. You can now only write a vector.
Just bringing up an old question to see if there is a solution since some time has passed. I've looked through most of the old threads and didn't find anything.
https://answers.arnoldrenderer.com/questions/10384/render-a-material-to-an-aov-nothing-fancy.html
Labels (3)
3 REPLIES 3
No, the answer is still the same:
Standard Surface returns a closure, not a color, that's why you cannot connect to the AOV Input.
// Stephen Blair
// Arnold Renderer Support
Gotcha - thanks! Do you foresee this being implemented in some other way to achieve the same goal of rendering a standard surface to an AOV?
What's the use-case where you need this AOV for?
As a workaround you can set an id in the standard surface shader rendered to an AOV which you can use as a mask in post.
