relativ path with procedural, export problems
hey guys,
i have a export problem with my procedurals: i distributed the procedurals, used only the object name in the path field and set the searchpath in the rendersettings. after this i want to export the scene-ass and render it with kick on a farm. i change the system searchpath with the kick command -set options.procedural_searchpath "/newpath/"
with a small amount of procedural everything work fine, but if i increase the numbers of the procedurals (maybe 1000) the export process took very very long time now. if i change the procedurals to an absolut path it woks fast, but than i lost the possibility to change it easy during the render process.
any idea why this problem happend and why it needs more time to export with relativ paths? or is there an other solution for this problem?
i use c4dtoa 2.3.1.3 and don't want update to 2.4 until this project is finished.
thanks a lot!!
marc.
