Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Refraction or SSS material?
3 REPLIES 3
Samuel_Suros
352 Views, 3 Replies
Hello, for the to the point I have had difficulty in achieving a plastic material for the lid of a transparent spray with a white base, here I leave an image of the reference photo so that you have an idea of what the material is, I hope you can help me.photo-2021-08-25-15-17-35.jpg
Labels (3)
3 REPLIES 3
lee_griggs
in reply to: Samuel_Suros
Have you tried mixing (mix_shader) a plastic material (SSS) with a material that has high transmission_weight and transmission_extra_roughness?
Lee Griggs
Arnold rendering specialist
AUTODESK
Slava_91
refraction with roughness and low diffusion or transmission depth percent
fow depth need use 3 or more volume ray depth
Samuel_Suros
@Lee Griggs Thank so much!!! that was the answer! easy hahhahaa
Technology Administrators
