ramp RGB images distribution
ahmednagah
ahmednagah
my scene contains magazine, I used ramp RGB to load page images and utility to distribute it
lee_griggs
Which color_mode is the utility shader set to?
Lee Griggs
Arnold rendering specialist
AUTODESK
peter.horvath6V6K3
Instead of the utility shader you can use a user_data_int shader with the index attribute, in case the pages are clones of the Magazine object in order. You also have to convert the index to the [0-1] range via a range shader.
You can also check this thread about a similar setup: https://answers.arnoldrenderer.com/questions/22656/assigning-different-colors-to-mograph-object-base...
