Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
R20 Team render clients crash
12 REPLIES 12
Message 1 of 13
albert.adler
1614 Views, 12 Replies
Hey,
I am using Cinema4D R20 and the latest arnold update. Everytime I hit the team render button some render clients crash instantly. I start with 20 clients but four renderings later there are just 8 available. Any ideas how to fix it?
Tags (1)
Labels (1)
12 REPLIES 12
Message 2 of 13
atoffey
in reply to: albert.adler
I had this issue in R20 also, but only when opening files originally saved from earlier versions of C4D or Arnold. Pasting the scene into a new file and manually re-entering the render settings fixed the crash issue — though still have color consistency issues between machines.
Message 3 of 13
albert.adler
Thank you Alice. I always used the render settings from R19. Hopefully this is the solution.
Message 4 of 13
Let me know if that solved the issue or not. Would be interesting to know if it's related only to Arnold or happens also with the Standard/Physical renderer.
Message 5 of 13
albert.adler
I still have this issue. 😞
Message 6 of 13
Could you please confirm if te Standard rederer works, so it's only an issue with Arnold? Do you have maybe a bugreport file or Arnold log on the clients which crash?
Message 7 of 13
bugreport.zip Here are the bugreports of a few render clients.
Message 8 of 13
Sorry for getting back to you so late. So far I'm not able to reproduce the problem, I don't have that many clients though. I don't see any c4dtoa related calls in the bugreport files, so I'm still not sure it's a bug in Arnold and not in the R20 Team Render. Can you test different renderers?
Aslo I wonder if this happens with any scene, or maybe there's something in one specific scene which triggers the issue? Is it single frame render or animation or both?
Message 9 of 13
kingcolombus
It's happen here whit the team render only ... no Arnold, and many client crash after a render job.
Message 10 of 13
This sounds like the issue is related to R20 Team Render and not specific to Arnold.
Message 11 of 13
guypavelo
I have the same issue, physical render. Animation or png sequence. It’s a heavy duty file though but still... don’t remember these issues with r19... debating on going backwards in version
Message 12 of 13
I see some R20 fixes on the MAXON beta forum, which has not been released yet. If you have access to the beta, please give it a try.
Message 13 of 13
albert.adler
Maxon told me to uncheck peer-to-peer box in the team render Settings. Now it works better.
