Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Question: Arnold Cinema 4D realistic shadow and lighting
3 REPLIES 3
jajachuk87
586 Views, 3 Replies
Hey guys,
I am trying to make a realistic product scene in Cinema 4d. I am playing around with a Physical sky lighting using Arnold. Can anyone explain how to make the realistic shadow and lighting look like this image below?
Thanx
Tags (2)
Labels (2)
3 REPLIES 3
madsd
in reply to: jajachuk87
Use an Arnold distant light, use either a real mesh tree/branch and position outside of camera frame so the stuff blocks the light, else use a clipart tree.
Color the shadows of the distance light to soemthing like dark brown.
I used the quick solution, cutout on a plane, but you should use a real tree as it has dimensions and the penumbra the blury shadows are changing depending on the distance to the wall.
jajachuk87
in reply to: madsd
Thank you!
jajachuk87
in reply to: madsd
Can you teach what is the difference between Arnold distant light and Arnold physical sky? Thanks,
Technology Administrators
