Problems with importing materials into the Asset Browser
Eden_Soto2
Eden_Soto2
I'm on R25 with the latest Arnold plugin and I'm consistently having issues when importing materials into the Asset Browser. If I import a material I've made where the image textures for the material are in the "tex" folder relative to the C4D document, once imported and dragged into a new document, the image references are still relative (just the original filename and extension with no path) without the "asset:\\path\to\image" type of formatting etc., so they all break... and furthermore, if I move to another machine and use the same Asset Browser library, the links will change from the actual filename (or asset:\\link type path) to something like "asset:\\file_XXXXXXXXXXXXX~" which becomes even more troublesome to relink all of them.
Is this a known issue? Is there a workaround for it? Maybe a specific way to import them into the Asset Browser so the links in the materials update properly?
peter.horvath6V6K3
The path should be changed automatically to the assetdb:// url format, when the material is added to the library. Not sure if it's a bug in Cinema 4D or something is missing from the plugin. I'll have to talk to Maxon to figure it out.
peter.horvath6V6K3
This should be fixed in C4DtoA 3.3.10. If you still have any issues, please let me know.
Not sure about this one, that sounds like a bug in C4D rather than the plugin. Please check the 3.3.10 build if it fixes the issue. If not, please check if the same happens with a native C4D material or it is specific to Arnold.
