Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Polygon Variation - like in C4D Variation shader
3 REPLIES 3
matthew
479 Views, 3 Replies
I have a question regarding shaders and mapping images or gradients for instance to polygons on a mesh or a parametric object. I've done it with the in-built C4D Variation Shader with Gradients and Projector. See attached JPG variance.jpg (gradients mapped to poly groups).
I have used the Arnold shader switch and rgb data shaders which works well on a per object basis. Can I use the Utility / Uniform ID and map to its output?
Any ideas? Thanks!
Tags (3)
Labels (3)
3 REPLIES 3
xebajac
in reply to: matthew
Use the color jitter node and the faces parameters.make sure to change the color from white.
matthew
Thanks!
@xebajac@zdfpost.net xebajac@zdfpost.net I have used the Color jitter / Face / Uniform ID with a black color and I'm getting a nice black to white range of color on the polygons. Is there a way to map to that as if they were separate polygons?
xebajac
your welcome...use a layer rgba or mix node and add a ramp node(map it the way you want ) then use it as a mix...Do you understand?
