Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Offset noise per object
1 REPLY 1
lizGYM66
160 Views, 1 Reply
I have a cloner with a bunch of instanced clones for flooring. How do I offset the noise on each object?
1 REPLY 1
peter_horvath
in reply to: lizGYM66
You can read the index of the clones via the user_data_int shader. So if you have 5 instances, this will return 0, 1, 2, 3, 4 per clone. You can plug it into a range shader to map to [0,1] or generate random numbers with it, etc.
// Peter Horvath
// C4DtoA developer
