Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Oddities I can't solve
4 REPLIES 4
atlas_designs
122 Views, 4 Replies
Having a bit of a brain cloud at the moment. For some reason Arnold is only rendering a small portion of the scene and the IPR isn't working. The picture viewer has become the IPR. I have verified the 'only render region' id off but no luck.
4 REPLIES 4
There's a feature in the IPR window to render to the viewport. Looks like it's turned on.
Go to the Render menu of the IPR window and look at the Render to Viewport option.
// Peter Horvath
// C4DtoA developer
Thank you very much. So only remaining issue is the render is limited to a small area.
Do you have a render region setup in the Render Settings?
Is it only in the IPR window or do you have the same result if you render to the Picture Viewer?
// Peter Horvath
// C4DtoA developer
Goes to show you how often I use Arnold! ha! Thanks again!
