Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
OCIO error when using Legacy colour in Deadline
5 REPLIES 5
swickerEY3VM
168 Views, 5 Replies
Cinema 4d R21
Arnold core 7.1.2.2
C4DtoA 4.2.4.1
It looks like when using the legacy colour settings in R21 a reference to a local OCIO config gets embedded into the ass files that I save out for Deadline to pass to our render farm:
color_manager_ocio
name /color_manager
config "/Applications/Maxon Cinema 4D R21/arnold/ocio/configs/arnold/config.ocio"
color_space_narrow "sRGB"
color_space_linear "scene-linear Rec.709-sRGB"
this then throws a rendering error as our Deadline/Arnold on the farm doesn't know about this local path:
Error
FailRenderException : 00:00:00 107MB ERROR | [color_manager_ocio] could not read '/Applications/Maxon Cinema 4D R21/arnold/ocio/configs/arnold/config.ocio' OCIO profile.
at Deadline.Plugins.DeadlinePlugin.FailRender(String message)
Any ideas about circumventing this? I assume that setting the colour management from Legacy to the default - Aces setting would help? Since these are legacy files I was hoping to avoid colour shifts from switching colour management settings.
Cheers, Simon W.
5 REPLIES 5
Can you add flags to kick, like so?
-set options.color_manager "" -d color_manager_ocio
// Stephen Blair
// Arnold Renderer Support
hi stephen,
thanks - will test this out tomorrow.
would these parameters be added only when you are using the legacy colour manager?
so if you were using the default - Aces colour management it would not be necessary to add this parameter?
cheers, simon w.
@swickerEY3VM wrote:
hi stephen,
cheers, simon w.
Right.
If you use "default ACES" then Arnold will use the OCIO config that ships with Arnold.
Since it's the default, no color_manager node will be exported to ASS.
// Stephen Blair
You can set the OCIO environment variable on the farm to point to the config shipped with Arnold ($ARNOLD_DIR/ocio/configs/arnold/config.ocio) and then use an ocio color manager with empty config in the scene:
color_manager_ocio
name /color_manager
config ""
// Peter Horvath
// C4DtoA developer
Thank you Stephen and Peter for your help! I think that information covers everything!
Cheers, Simon W.
