Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Negative Light?
2 REPLIES 2
593 Views, 2 Replies
Negative Light?
I was just thinking if it would be possible to make a "light" that instead of light projects darkness? I know this is physically impossible, but it would be incredibly handy when lighting a scene, where it is always much more easy to light a specific thing than to darken it. It's probably not possible to it within the vanilla Arnold, but maybe with a kind of tiny "mini-plugin" could it be possible? Something like a projected shadow that absorbs the light it hits?
Labels (4)
2 REPLIES 2
lee_griggs
This is an old trick from the '90s (yes I am old) for faking lighting. Quite expensive to render I seem to remember. Why would you want to do this in a physically accurate renderer? The light_blocker might be of some use instead.
Lee Griggs
Arnold rendering specialist
AUTODESK
in reply to: lee_griggs
Only for artistic reasons. I also use a ton of light linking, which ins't physically accurate too.
Thanks for the light_blocker tip, I played around with gobos and slates but this might work as well.
Thanks!
Technology Administrators
