Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
MOTION BLUR doesn't render in Cinema 4D ?
3 REPLIES 3
Aaron_D1
1202 Views, 3 Replies
Recently I've been learning Arnold for Cinema 4D following the course on Morgraphplus.com. But when I was learning how to setup the motion blur, I found my IPR won't render it(Motion blur switch is checked, and I was doing exactly what the author was doing).
Is this a bug? Or is there something else I need to do to make the motion blur render happen?
SPECS:
Arnold for Cinema 4D v2.2.2
Windows 10 1709
Tags (1)
Labels (1)
3 REPLIES 3
Aaron_D1
in reply to: Aaron_D1
Alright, I've solved this. There is an option "Enable motion blur" in the IPR window which I didn't know exist. Check this, then everything is fine.
Yes, there's a separate control in the IPR Window because of performance reasons. When motion blur is enabled in the IPR, updates become slower because the active scene has to be cloned. So it's disabled by default.
I'm planning to make this control more obvious in a future release.
That would be much better if so. Thanks, Peter.
Technology Administrators
