Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
More Noice Questions :)
5 REPLIES 5
mckenzie2VER2
187 Views, 5 Replies
How do I get de-noised passes saved in an .exr? My .exr has a de-noiced RGB but individual passed aren't de-noised.
5 REPLIES 5
You have to provide the additional AOVs
In the UI, use the Light Group AOVs field. On the command line, use the -l flag.
It's simpler if you render a merged EXR, otherwise you need to add a -i flag for each AOV
// Stephen Blair
// Arnold Renderer Support
I have noice as an imager with merged aov's checked - so it cleans the beauty but not the other passes.
Are you saying I use the noice imager to get the aov's out into an exr, then use the command line noice to clean the various passes?
No, I thought your noice question was about noice, the standalone denoiser executable.
An Imager has a Selection tab, where you can select what AOVs are processed by the imager.
// Stephen Blair
So I have the noice imager in the IPR with a selection, however it will only save the file out if rendered via the picture viewer. I guess this is correct? Otherwise it all works.
Yes, that's correct. Output is not saved during an IPR session, only final render (e.g. Render to Picture Viewer, Commandline, etc.).
// Peter Horvath
// C4DtoA developer
