Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Missing the AOV filters under the AOV render settings tab
1 REPLY 1
chatect
113 Views, 1 Reply
Im trying to render out an alpha channel for toon shader without just getting lines, and I don't see anything in the space where in all of the info on how to do this, theres usually an ability to add a 'box' and 'contour' filter. But mine is just blank. Am i missing something?
EDIT: Of course I found it right after posting this lol. Incase an future onlooker has this issue, it gets moved to your list with all of your objects, cameras, lights, objects, etc, its under a group probably titled 'display driver'.
1 REPLY 1
peter_horvath
in reply to: chatect
I think MtoA has the properties of the selected AOV under the list. In C4DtoA, you can edit properties on the AOV objects in the object tree, as you figured.
// Peter Horvath
// C4DtoA developer
