Memory Overload freezing render
Francis_Bievre
Francis_Bievre
Working on C4D, I am doing some renders with several characters, something like 15 hair systems (cached), an infinite ocean generated from a houdini displacement map (animated) with each map being around 250 mega, motion blur, etc.
The reason I give all these infos is that it is the 1st time I run into this problem : I launch my render and when I come back 12 hours later, it froze after something like 200 frames. It happened twice on two different shots. I have a warning from MacOS that there is a memory overload, so it stopped C4D.
I have to close C4D and restart the render from the frozen image.
But why ? Is it a normal behavior from Arnold ?
I'm on MacOS with 64gigas of RAM.
Thank you !
Francis
Stephen.Blair
Got an Arnold log so we can see what's going on? Are all textures tx? Whats the texture cache size? What version C4DtoA? How much memory is being used to render each frame.
// Stephen Blair
// Arnold Renderer Support
Francis_Bievre
Hi Stephen,
-No Arnold log sorry
- yes all textures are tx, except the 100 images of the animated displacement map
-I'm sorry but I don't know where to find the cache size, but the indicated max cache size in settings is 2048MB
-2.4.0.1
-when rendering a frame in the IPR, it is written "mem : 7142.02MB"
Thank you !
Francis_Bievre
Oh it is 2.4.0.2 sorry
Stephen.Blair
7142mb isn't that much, so something else must be happening
per-frame logs would show us whether there's an increasing amount of memory being used each frame, because we would get something like this:
 565MB         | ------------------------------------
565MB | memory consumed in MB:
565MB | at startup 519.02 565MB | plugins 1.96 565MB | AOV samples 53.87 565MB | output buffers 21.49 565MB | node overhead 0.00 565MB | message passing 0.08 565MB | memory pools 30.05 565MB | geometry 0.02 565MB | polymesh 0.01 565MB | curves 0.01 565MB | accel. structs 0.04 565MB | strings 12.01 565MB | texture cache 0.00 565MB | profiler 0.10 565MB | unaccounted -22.67 565MB | total peak 615.87
// Stephen Blair
Francis_Bievre
Ok I'll give you the log next time it happens then !
peter.horvath6V6K3
I wonder if it's related to hair. I remember there was a memory leak in the plugin before (in 2.0.0) while exporting the guides. It was fixed than, but who knows.
