Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Maya to Cinema 4D
12 REPLIES 12
Message 1 of 13
kokoerico
3218 Views, 12 Replies
Maya to Cinema 4D
Is it possible to convert a Maya scene to Cinema 4D and preserve all shaders and lights?
If yes, would it render exactly the same?
Can anyone help me to convert this scene to Cinema 4D: https://docs.arnoldrenderer.com/display/A5AFMUG/Learning+Scenes?preview=/71009630/86805056/Sophie_us...
Tags (2)
Labels (2)
12 REPLIES 12
Message 2 of 13
lee_griggs
in reply to: kokoerico
You can export the shaders and import them as .ass files. FBX should preserve the shader assignment. You will just have to replace the shaders.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 13
As Lee said, you can export and import shaders. Note that some DCC specific shaders are not supported, for instance you can not translate a C4D Noise shader to Maya. Also check the length units because they are different in Maya and Cinema 4D. The default in Maya is 1 cm while it's 1m in C4D. You can change that in the render settings in C4DtoA (Export scale).
Message 4 of 13
kokoerico
Thank you both for the reply.
I managed to successfully import it as an FBX into C4D, and imported the shaders as an .ass file.
I’ve used the same settings. However, I can’t get it to render the same way in C4D.
In theory, if all the settings are replicated, would MtoA and C4DtoA render exactly the same?
Message 5 of 13
In theory, yes. What can make a difference is length units, color space settings, etc. You can export the scene from Maya and C4D to an ASS file and compare them, maybe you can see where the difference is coming from.
Message 6 of 13
lee_griggs
Can you post some images to see how you are progressing?
Lee Griggs
AUTODESK
Message 7 of 13
kokoerico
in reply to: lee_griggs
Hi Lee,
I have made some good progress importing the scene + shaders in C4D. Not quite matching yet. I'm struggling with the skin. Any ideas?
Message 8 of 13
lee_griggs
Nice! Maybe multiply the color texture with a warmer skin tone color? Are you using SSS?
Lee Griggs
AUTODESK
Message 9 of 13
kokoerico
Hi Lee,
I was using SSS, but the scale was off. I got it sorted now, and it is looking much better.
Many thanks for your help!
Message 10 of 13
Thanks Peter. I managed to get that sorted.
The scale difference was the main issue.
Message 11 of 13
lee_griggs
That's great! Would you be willing to share the scene so that we can add it to the C4DtoA docs too?
Lee Griggs
AUTODESK
Message 12 of 13
kokoerico
Hi Lee,
Here's the C4D scene file. https://www.dropbox.com/s/plamud7mexln6ct/Sophie_C4D.zip?dl=0
I think I got it to match fairly closely, but not perfect. Any other suggestions would be most welcomed.
Message 13 of 13
lee_griggs
Thank you, Koko!
Lee Griggs
AUTODESK
Technology Administrators
