Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Material node instancing
2 REPLIES 2
278 Views, 2 Replies
Hello Everybody, I have 3 leaf Materials and I would like to control color correct nodes inside of them remotely, I though of creating color correct instance and than drag and drop it inside materials. But It does not work as I though. Is such thing even possible?
Cheers,
Daniel
1. Color Correct "Shader"
7063-screenshot-2020-05-18-at-074643.png2. import it into leaf shader, but cannot plug in color information in ๐Ÿ˜ž
Tags (2)
Labels (2)
2 REPLIES 2
peter.horvath6V6K3
It's not possible. Linking different shaders to the input requires different shader instances. A workaround could be to setup an xpresso network to control all three color correct shaders, which may not be so convenient.
in reply to: peter.horvath6V6K3
that with xpresso network is a good idea, thanks
Technology Administrators
