Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Limit Atmosphere to One Light?
5 REPLIES 5
3029 Views, 5 Replies
I have a scene with a spot light and atmosphere behind some trees. I also have a quad light used as a fill to give more definition to the main object in the scene. However, the atmosphere volume is also emanating from the quad light, which I do not want. Is there a way to limit the atmosphere volume to one selected light only?
Thanks.
Tags (2)
Labels (2)
5 REPLIES 5
peter.horvath6V6K3
What about setting the Volume contribution to 0 on the Main tab of the quad light?
Thanks! That was so obvious, I can't believe I didn't think of it.
Samir_Riman
Hi Peter, it may seem stupid or obvious but I cant find the Volume Contribution option in the main tab! Would you be kind enough to give me directions?
Stephen.Blair
in reply to: Samir_Riman
volume contribution
// Stephen Blair
// Arnold Renderer Support
@Samir Riman
It is in the Attribute editor of every light, under the Arnold section, open the visibility tab. It is the 5th parameter.
