From License Diagnostics:
License diagnostics executed at 2022-06-27 10:48:01
Autodesk Desktop Licensing Version: 12.0.0.6529
Installing AdskLicensingUpdateTool to /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold
unzip /Applications/Maxon Cinema 4D R26/arnold/license/installer/AdskLicensingSupportTool-2.1.0.446-mac.zip -d /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold
kick -nostdin -v 1 -i /dev/null (1.64 sec)
00:00:00 57MB | log started Mon Jun 27 10:48:01 2022
00:00:00 57MB | Arnold 7.1.2.0 [a68d7fc3] darwin clang-10.0.1 oiio-2.4.0 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 2022/05/19 13:04:33
00:00:00 57MB | running on Shanes-Mac-Pro.local, pid=15415
00:00:00 57MB | 1 x Intel(R) Xeon(R) W-3245 CPU @ 3.20GHz (16 cores, 32 logical) with 98304MB
00:00:00 57MB | macOS 10.16.0, Darwin kernel 21.4.0
00:00:00 57MB | soft limit for open files is set at 10238
00:00:00 57MB |
00:00:00 74MB | [color_manager_ocio] default ocio.config found in /Applications/Maxon Cinema 4D R26/arnold/bin/../ocio/configs/arnold/config.ocio
00:00:00 74MB | loading plugins from /Applications/Maxon Cinema 4D R26/arnold/bin/../plugins ...
00:00:00 74MB | loaded 5 plugins from 3 lib(s) in 0:00.01
00:00:00 74MB | [kick] command: /Applications/Maxon Cinema 4D R26/arnold/bin/kick -nostdin -v 1 -i /dev/null
00:00:00 74MB | loading plugins from . ...
00:00:00 74MB | no plugins loaded
00:00:00 78MB | [ass] loading /dev/null ...
00:00:00 78MB | [ass] read 0 bytes, 0 nodes in 0:00.00
00:00:00 78MB |
00:00:00 78MB | authorizing with license manager: user ...
00:00:01 91MB WARNING | rendering with watermarks because of failed authorization:
00:00:01 91MB | [clm.v2] SERVICE (7): login requires GUI mode
00:00:01 91MB | environment variables:
00:00:01 91MB | ARNOLD_LICENSE_ORDER = (not set)
00:00:01 91MB | ARNOLD_LICENSE_MANAGER = (not set)
00:00:01 91MB | [rlm] solidangle_LICENSE = (not set)
00:00:01 91MB | [rlm] RLM_LICENSE = (not set)
00:00:01 91MB | [clm] ADSKFLEX_LICENSE_FILE = (not set)
00:00:01 91MB | [clm] LM_LICENSE_FILE = (not set)
00:00:01 91MB |
00:00:01 91MB |
00:00:01 91MB | releasing resources
00:00:01 91MB |
00:00:01 91MB | Arnold shutdown
kick -licensecheck (0.10 sec)
RLM DEBUG for product "arnold"
0 product instances found
Could not find any license files, please check the license server, the license may be expired
Please contact licensing@solidangle.com
environment:
solidangle_LICENSE = (null)
RLM_LICENSE = (null)
AdskLicensingSupportTool --version (0.65 sec)
AdskLicensingSupportTool Version: 2.1.0.446.
AdskLicensingSupportTool --info (0.33 sec)
---VERSION INFORMATION---
Service status: Running
AdskLicensingService version: 11.2.3.2987
Installer version: 12.0.0.6529
AdskLicensingAgent version: 5.12.1.2153
AdskLicensingInstHelper version: 2.11.0.666
AdskLicensingSupportTool version: 2.1.0.446
---LICENSING V2 PRODUCTS INFORMATION---
There are 3 Licensing v2 Autodesk products registered on this PC.
PRODUCT 1
feature_id: ARNOL
def_prod_key: C0PN1
def_prod_ver: 2022.0.0.F
sel_prod_key: C0PN1
sel_prod_ver: 2022.0.0.F
authorize_succ: True
supported_lic_methods: Network, Standalone, User
serial_number_sa: xxx-xxxxxxxx
serial_number_nw: xxx-xxxxxxxx
icon: /uiassets/1f671890837ccfded41f4e4c00f5451e.png
background: /uiassets/640d6886f3593fa572049bd0d2a702f5.png
highlight: {'red': {'value': 157}, 'green': {'value': 198}, 'blue': {'value': 204}, 'alpha': {'value': 1}}
sel_lic_method: User
PRODUCT 2
feature_id: ARNOL
def_prod_key: C0PO1
def_prod_ver: 2023.0.0.F
sel_prod_key: C0PO1
sel_prod_ver: 2023.0.0.F
icon: /uiassets/c4f6b5cecde5b62d070d48a59fd2c59b.png
background: /uiassets/c604a30d986b3be0ead7de7f6c9c78a9.png
PRODUCT 3
feature_id: MAYA
def_prod_key: 657O1
sel_prod_key: 657O1
user_lic_enabled: True
trial_enabled: True
cls_check_succ: True
icon: /uiassets/caa7e45afa57d77aff9601c221539a87.png
background: /uiassets/c192fce10832d507e9faac27d8775d45.png
highlight: {'red': {}, 'green': {}, 'blue': {}, 'alpha': {}}
AdskLicensingSupportTool --getlogs /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold/AdskLicensingLogs (0.56 sec)
Successfully collected Licensing files.
Successfully collected Sdk files.
No Webservice log files found in:
/Library/Application Support/Autodesk/Web Services/Log/WebServices.log
No Loginstate log files found in:
/Library/Application Support/Autodesk/Web Services/LoginState.xml
Successfully collected Install files.
No Adlm log files found in:
/Library/Application Support/Autodesk/AdskLicensingService/Log/adlm-err*.log
WARNING: The following collected logs are NOT verbose
AdskLicensingService.2022-06-26.001.log, AdskLicensingService.log, AdskLicensingService.2022-06-27.001.log, AdskLicensingService.2022-06-25.001.log, AdskLicensingAgent_2022-06-25_11-46-33-884_882ba9cc-9691-4f8c-46a7-e7cfd3bbe4df.log, AdskLicensingAgent_2022-06-27_10-27-53-489_fc188d9f-09c6-4412-79a2-9138966b10dd.log, AdskLicensingAgent_2022-06-26_17-04-19-929_ba86c326-15d7-4b35-51ff-95d1705b6ade.log, AdskLicensingAgent.log, AdskLicensingAgent_2022-06-27_10-34-18-103_512529ad-2050-45da-575e-262f47920453.log, AdskLicensingAgent_2022-06-27_10-47-36-877_6a6bf199-1229-47eb-5db0-79eafb361f77.log, AdskLicensingAgent_2022-06-26_12-40-14-498_5bc05bb8-1199-4bab-6ac7-be8c3afa542a.log, AdskLicensingAgent_2022-06-27_10-48-02-069_8f82a0c0-1ae8-4c2f-6bca-9f66df32a90a.log, AdskLicensingAgent_2022-06-26_17-05-29-325_30be9764-dad5-409a-6c6a-c73eeebca753.log, AdskLicensingAgent_2022-06-25_11-46-33-565_40b49125-e136-4543-615e-9ffdd73f5e2a.log, AdskLicensingAgent_2022-06-27_10-48-02-094_6356d2ed-5293-47a5-6276-c52f41ac0f6e.log, AdskLicensingAgent_2022-06-27_10-27-53-471_53b8ac9f-8250-4e98-7da5-db98d675a5b0.log, AdskLicensingAgent_2022-06-25_11-46-44-924_00fbf3b3-126c-4878-7e40-10030be5f47d.log, AdlSdk-ArnoldLicenseManager-11375.log, AdlSdk-15364.log, AdlSdk-15415.log, AdlSdk-ArnoldLicenseManager-15364.log, AdlSdk-11375.log, AdlSdk-14190.log, AdlSdk-14822.log, AdlSdk-ArnoldLicenseManager-11123.log, AdlSdk-10258.log, AdlSdk-Arnold-14190.log, AdlSdk-ArnoldLicenseManager-14249.log, AdlSdk-14249.log, AdlSdk-Arnold-15415.log, AdlSdk-ArnoldLicenseManager-10258.log, AdlSdk-11123.log, AdlSdk-ArnoldLicenseManager-14822.log.
Run the -svl command to set verbose logging.
WARNING: Verbose logging found enabled in
AdskLicensingAgent_2022-06-27_10-26-50-362_48ffa98d-df2f-4b53-7681-2718a3b27035.log.
Run the -sdl command to reset to the default logging level to reduce unnecessary disk space usage.
Log files and info collected to: /Users/shanemckenzie/Library/Application Support/Autodesk/Arnold/AdskLicensingLogs/info-and-logs.zip
lmutil lmstat -S adskflex -a -f 87752ARNOL_2023_0F (0.38 sec)
lmutil - Copyright (c) 1989-2018 Flexera. All Rights Reserved.
Flexible License Manager status on Mon 6/27/2022 10:48
Error getting status: Cannot find license file. (-1,359:2 "No such file or directory")
rlmutil rlmhostid -q ether (0.15 sec)
e450ebb80b54 e450ebbd0489 88665a37db84 029481a9dc0d 029481a9dc00
FlexLM environment (0.00 sec)
ADSKFLEX_LICENSE_FILE (local env) =
ADSKFLEX_LICENSE_FILE (global user env) =
Adlm FlexNET cache =
Adlm FlexNET cache location = /Users/shanemckenzie/.flexlmrc
