Layering a logo on top of another texture
elik
elik
I need to overlay a logo with a white letter on to a corroded metal corrugate wall. The issues I am running into is how to get the wall image onto the geometry without tiling or having the white letter be transparent. The metal texture is procedural.
peter_horvath
Not sure I understand the problem. Does the native method not work? Stacking the logo over a base material and change offset and scale in the texture tag? Or using the layer shader?
// Peter Horvath
// C4DtoA developer
elik
  • I stacked it which seemed to work, but thought I’d have more control using layering. I ran into a challenge with the alpha channel on the logo as it was the same size as the .
kakensa
Check Out Chad Ashley GSG Tutorial he did exactly what you are trying to achieve.
https://youtu.be/RHoeYXJOqZw?list=PL_KyR3yGDJFsJ5jjeAD4IVXVALdrpKbO6
