Arnold render empty or a part of the scene. This issue is serious because you just often only find it out along render sequense. So hard to find an alternative when the scene is huge with many completed - lookDev asset/cloners. I also find this bug in older versions. Hope you can fix it. Thanks
This is project, render sequense video :
https://drive.google.com/drive/folders/1SkgmhSGa4_imt5WGY97q2xq8jy7PnDV1?usp=sharing
Can someone at least feedback to me about this issue ? Thanks in advance!
Thank for feedback. I don't really understand you word but if you mean I provide a log for you by press Shift + F10, then sorry there is no log. It's written nothing in the log. That 's just an nature happening issue, without any notify. I did provide a link of project above. You can download and check it.
Making reference to this -> https://docs.arnoldrenderer.com/display/A5AFCUG/Log
The scene renders fine if you change the Instance Mode of the Cloner to Instance or Render Instance.
Not sure yet what's wrong with the Multi-Instance mode, need to investigate further.
Meanwhile a workaround could be to change the Scale of the Plain Effector from -1 to -0.99 for instance. Or switch to Render Instance mode as I mentioned above.
Excellent found. This is just a small test. Since C4D have multi-instance mode, C4D user never use instance or render-instance in large scene. Because it will destroy the computer. Actually render-instance mode is useless nowaday. Thank you for finding the error !
