Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Is it possible to render an Object Mask that does not show up in the refraction of an object ?
2 REPLIES 2
Andreas_KrauÃ_er
436 Views, 2 Replies
Is it possible to render an Object Mask that does not show up in the refraction of an object ? Whenever I have an object in the scene with refraction, the mask shows up in the refraction of that object. (See example below, the mask should only be for the ground).
This problem seems to only appear when i render in the picture viewer.
Thanks in advance for any tips.
Tags (3)
Labels (3)
2 REPLIES 2
Yes, that's currently a bug in the aov_write shaders (which the object mask tag uses).
Ah ok, good to know. Thank you.
Technology Administrators
