Is Cryptomatte working on R26?
diego6S3FN
diego6S3FN
Hi, I am trying to work with Cryptomatte as I have done on many times but now it seems to have stopped working.
I can't see it in IPR and in After Effects latest version I get a message: "No Cryptomatte layers found".
I have used .exr driver to export them and also on Display
I am using R26 + C4DtoA 4.4.0.1 On windows 10 this happens on two computers the same.
I have seen that other users seem to have had the same issue but I have not found any solution.
Ok, solved: I forgot to add it in Advanced AOV shaders
Diego
peter_horvath
You can also run the Setup Cryptomatte script from the Arnold > Utilities menu, which does the setup for you.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Utilities_ci_Setup_Cryptomatt...
// Peter Horvath
// C4DtoA developer
diego6S3FN
Thanks Peter, I didn't know this option, I always adjusted it by "hand". this utility is great!
