IPR WIndow doesn't work (black window)
Matteo_Leoni
Message 1 of 12
Matteo_Leoni
my IPR Window doesn't work, black screen and no info in the IPR Window command line.
But when I start the render in the C4D picture viewer, it works.
I have Nvidia Quadro K620 with latest driver.
May you help me? Thank You
Replies (11)
Message 2 of 12
Stephen.Blair
Check the Arnold log.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 12
Matteo_Leoni
Message 4 of 12
Stephen.Blair
Was the IPR already open? Can you start a new, empty scene, create a sphere and a skydome light, set the verbosity level to Info, and then open the Arnold IPR window?
// Stephen Blair
Message 5 of 12
Matteo_Leoni
C4DtoA | 00:00:18  2074MB         |
C4DtoA | 00:00:18  2074MB         | releasing resources
C4DtoA | 00:00:00  2073MB         | Arnold shutdown
C4DtoA | 00:00:00  2073MB         | log started Fri Oct 13 18:12:50 2017
C4DtoA | 00:00:00  2073MB         | Arnold 5.0.1.4 [acf16ee8] windows icc-17.0.2 oiio-1.7.15 osl-1.9.0 vdb-4.0.0 clm-1.0.3.513 rlm-12.2.2 2017/09/19 11:03:16
C4DtoA | 00:00:00  2073MB         | running on G11-matteo, pid=1088
C4DtoA | 00:00:00  2073MB         |  1 x Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (4 cores, 8 logical) with 16327MB
C4DtoA | 00:00:00  2073MB         |  Windows 7 Professional Service Pack 1 (version 6.1, build 7601)
C4DtoA | 00:00:00  2073MB         |  soft limit for open files raised from 2048 to 2048
C4DtoA | 00:00:00  2073MB         | loading plugins from C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA\procedurals ...
C4DtoA | 00:00:00  2073MB         | volume_tfd.dll: volume_tfd uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | [metadata] loading metadata file: C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA\procedurals\volume_tfd.mtd
C4DtoA | 00:00:00  2073MB         | volume_voxel_field.dll: volume_voxel_field uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | [metadata] loading metadata file: C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA\procedurals\volume_voxel_field.mtd
C4DtoA | 00:00:00  2073MB         | loaded 2 plugins from 2 lib(s) in 0:00.01
C4DtoA | 00:00:00  2073MB         | loading plugins from C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA\shaders ...
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: c4d_texture_tag uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: c4d_texture_tag_rgba uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: mesh_light_material uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: normal_displacement uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: vector_displacement uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: c4d_vertex_map uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: xparticles uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: image_plane uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: layer_color uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: layer uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | c4dtoa_shaders.dll: xp_gaseous uses Arnold 5.0.1.4
C4DtoA | 00:00:00  2073MB         | [metadata] loading metadata file: C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA\shaders\c4dtoa_shaders.mtd
C4DtoA | 00:00:00  2073MB         | loaded 11 plugins from 1 lib(s) in 0:00.01
C4DtoA | 00:00:00  2073MB         | [metadata] loading metadata file: C:\Program Files\MAXON\CINEMA 4D R18\plugins\C4DtoA/c4dtoa.mtd
Message 6 of 12
peter.horvath6V6K3
Do you have the viewport (Editor Window) open? There's a known limitation in the plugin, the IPR Window does not update when the viewport is not visible.
Message 7 of 12
Shawn_Kearney1
This probably isn't the issue, but check your scale and zoom on your IPR. If it's a very small number then this will happen. I am not sure why, but this happened to me. I suspect that for whatever reason it was set like that and I accidental saved it into my new.c4d file.
Peter - Since we're on this subject, specifically my IPR zoom and scale are/were set to their minimums (zero and something like 0.01 respectively) I am pretty sure I would not have set these up that way, though anything is possible. If this is the case of Matteo as well, then maybe a bug?
Message 8 of 12
peter.horvath6V6K3
I remember an issue in the past where the scale input was in focus when opening the IPR window, so typing or scrolling messed it up. But I think I've fixed that, at least I did not meet this problem recently. If you can reproduce it, just let me know and I'll take a look.
Message 9 of 12
Shawn_Kearney1
For the next few weeks I'll be working in After Effects, but next time I'm in c4d I'll try to reproduce and report back.
Message 10 of 12
Matteo_Leoni
Thank You Shawn, it works! I don't know why my IPR scale was 0% and then black screen on IPR! Now I set scale 100% and render works!
Message 11 of 12
Sunny_Suppy
Thanks Shawn Kearney
Message 12 of 12
duff
5 years later this helped me!
