ipr showing watermarks
Glyn_Dyer
Glyn_Dyer
Im having problems with Arnold in C4D in that the IPR window is showing watermarks. Ive just installed LMTOOLS and followed all the instructions for installing the new licence and nothing has changed. Its telling me the license is installed but still watermarks in the IPR window. What do i need to do please to resolve?
Stephen.Blair
What tells you the license is installed? That sounds like you're trying to install the license as a node-locked license.
Did you set the ADSKFLEX_LICENSE_FILE environment variable?
https://support.solidangle.com/x/1JDhAw
If you're using the latest C4DtoA, then you can use Plugins > C4DtoA > Help > Licensing > Connect to License Server.
If the license server is on the same machine as CINEMA 4D, then you can enter @localhost
If you're still getting a watermark, check the Arnold log:
https://support.solidangle.com/x/jZPhAw
I would also check the license server. On the LMTOOLS > Server Status tab, click Perform Status Enquiry.
// Stephen Blair
// Arnold Renderer Support
Glyn_Dyer
Stephen,
thanks for your reply but I haven't got a degree in computer programming and I'm just a NOOB. All this is over complicated and pretty extreme just to install software. What happened to simplicity?
Out of desperation I deleted everything off my computer relating to Arnold and did a fresh install and its worked without having to go through any of this complicated process just to get the license file to work.
Stephen.Blair
I understand that setting an environment variable and checking the Arnold log might seem complex, but those actions do not require a degree in computer programming.
If you have an Autodesk license that requires the Autodesk Network License Manager, I don't see how a fresh install of Arnold would set up the license server, or set the required environment variable.
// Stephen Blair
Glyn_Dyer
Well I don't know but its worked so I'm up n running and happy. As an end user all I want is simplicity and ideally a two click solution- 1 click to install the software and 2 clicks to install the licence. Anything more than that is off putting because someone like me has no idea what it is they are modifying.
nachocaro78
Community Visitor
Community Visitor
The watermark still appears on my Mac M1 with Cinema 4D and Arnold 2024, I have already reinstalled it many many times and I have not been able to get it to disappear, can someone help me. Thanks in advance
peter_horvath
Can you please check the error messages in the Console? Did you sign in with your Autodesk account in the License Manager?
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Getting_Started_ci_Licensing_...
// Peter Horvath
// C4DtoA developer
