Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Invalid image file " ": ImageInput :: create () called with no filename - C4DtoA
1 REPLY 1
s.koltsov
413 Views, 1 Reply
I use TeamRender and when the material has an Absolute Path, everything is fine, but when I add this material to the library and the path to the material has "preset: //my_lib.lib4d / ..." then a log appears on TeamRender computers - Invalid image file " ": ImageInput :: create () called with no filename
Labels (3)
1 REPLY 1
Does the library with the same material exist on the client machines? I'm not sure it's automatically transferred to the client. Does the Standard render with the same setup work?
