Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Infinite Ocean
4 REPLIES 4
Francis_Bievre
637 Views, 4 Replies
Infinite Ocean
Hi guys,
Has anyone ever tried to render an infinite ocean with C4DtoA ? I'm trying to get a result using noise but it is not good enough as my camera needs to fly like 1 meter over the surface of the water ...
I also have Houdini Indie but didn't find a way to import the large scale ocean to C4D (yet) ?
Any advice appreciated.
Cheers,
Francis
4 REPLIES 4
Well, I was moving forward with noise and displacement but now I get triangles in my renders, as if Arnold was not smoothing the plane properly
lee_griggs
in reply to: Francis_Bievre
You may need to increase subdivision iterations for the plane.
An ocean tutorial is available here.
Lee Griggs
Arnold rendering specialist
AUTODESK
Hi Lee,
Thank your for taking the time to reply.
Yes I know this tutorial but it does not help me getting an infinite ocean, unfortunately. But it gave me the idea to try exporting a 4k displacement map of a looped Houdini large ocean and use it in C4DtoA.
I'm a beginner at Houdini but I'll post a few images if it works to help someone in the future ...
Cheers
It worked ! I exported a 100 frames loop of a Houdini ocean (500m*500m) as 32bits displacement maps in .exr
I apply it to a 250m*250 plane in C4D (500 was too big I had to push the iterations levels too high for animation ...) and tadaaaah, it works ! Here is a quick test render.
I think I will render twice for the final animation : once with my 250m2 sea, then with a huge sea with no subdivision that I will composite under my detailed sea in post, so that my sea reaches the horizon.
For people rendering with the standard renderer there is an infinite ocean plug-in for C4D, but when you use a third party engine it's quite complicated ....
