Inconsistent color picker when using Legacy Linear workflow
lizGYM66
lizGYM66
If your not using ACES and are using the now Legacy Linear color management workflow in C4D,  the color picker doesn't work correctly. It's consistent behavior to. If you select a color, then exit out, the swatch will change to a lot darker color. When you re-click on the swatch it's set a different value. It always "sticks" on the 2nd attempt. This bug has been around before and happened with Redshift to, so I suspect its a C4D problem but wanted to leave it here just in case there is anything you can check your end.
lizGYM66
peter_horvath
The color picker and the color swatch is a native Cinema 4D tool and widget, and color management in the display is managed internally, we don't have any control over it. I suggest reporting the issue to Maxon, because it sounds like a Cinema 4D UI bug.
// Peter Horvath
// C4DtoA developer
